Noisy G1050 Hydraulics
Larry
12-16-2001 23:50:04
Our G1050 hydraulics work, but when the lever is in the neutral position, we get a very loud, noisy vibration, seemingly in the pump.
Sticking relief valve?
What is the fix?
Thanks to all, Larry
Harrold Rhodes
12-17-2001 07:36:02
 Re: Noisy G1050 Hydraulics in reply to Larry, 12-16-2001 23:50:04
The 1050 row crop had closed center hydraulics. A common problem was air in system. Loop a hose in one of remote couplings and circulate oil to remove air. It can also be sucking air into system. If so try to locate where and stop it.. The pressure compensating valve on pump can be set too high.
