Steering shaft universal joint --zau
walt f
12-05-2001 21:43:45
how and where would i find a universal joint for the steering shaft on a 1949 zau and how are the pins held in that hold the universal joint on the shaft, thanks---walt
DLP
12-07-2001 04:53:43
 Re: steering shaft universal joint --zau in reply to walt f, 12-05-2001 21:43:45
I've noticed some parts sources have the steering u-joint assemblies available. Just make sure the shaft diameter is correct. Some I've noticed have a keyed slotted hole & a set screw. If it does, take it to a drill press & drop a hole through it the same diameter as the pin hole in the shaft (3/8" I think).
Jim Parisot
12-06-2001 09:54:01
Walt,
The pins are simply driven in but not usually so easily driven out, what with age and rust, but should drive out with a punch and a little penetrating oil applied ahead of time and a little effort and patience. I don't think anyone sells those original Blood Bros. u-joints, but you could buy regular u-joints of that size wherever they are sold. One fella a while back had the idea to heat the originals and then squeeze the sides in a vice or press to take out the play. I haven't tried it, but it sure sounds like it's worth a try. Also, I think an Agco dealer may still have a part number (replacement) for that u-joint. Hope this helps.
Jim
