R or Z that is the question.
MM rookie
12-05-2001 19:04:25
How do you tell a R engine from a Z engine from the outside if the tag is gone? Found a engine but don't know what it is for sure. I heard you can tell by the oilpan somehow. Thanks
Jim Parisot
12-06-2001 09:43:01
 Re: R or Z that is the question. in reply to MM rookie, 12-05-2001 19:04:25
MM Rookie,
Easiest way is to just look at the casting numbers on the main case. They are on the right side of the case in the top right hand corner. A ZT engine will have RE151A, a ZA will have RE200. An earlier RT will have EE151 and a late RT will have 10A261. And, I'm not mixing this up, Z engines had part numbers with RE prefixes, the R engines had EE prefixes. Hope this helps.
Jim
