Parts missing on M670
J.Simmons
12-05-2001 14:37:28
I have a chance at a M670 it has some parts missing.I don't know much about MM's.The part that is missing is if you are sitting on the tractor it's under the right foot it's looks like it may be round it has a gear coming out of the housing.I know I didn't give you much to work with but any help would be great.If you do know what this is can somone tell me where to find it and about how much it cost ?Thanks in advance.
JK
12-05-2001 19:54:17
 Re: parts missing on M670 in reply to J.Simmons, 12-05-2001 14:37:28
It sounds like you are looking at the bull pinion shaft where the brakes are normally located but are apparently missing. If this is so, you will need two brake discs, 1 brake actuator assembly, one outside brake platem, three 5/8" bolts and whatever brake linkage is missing to connect it to the brake pedal. The parts should be available from several of the parts sources listed on the M-M site.
John
