One more time
Jason
11-05-2001 13:53:48
Once again can someone shed some light on the U moline 800 head conversion. I was told to run 800 heads and jugs on U moline crankcase with G rods and crankshaft. This would require a spacer from G rods to 800 pistons. This should make somewhere over 500 cubic inch, I was told. Thanks for your info.
Glenn
11-08-2001 19:24:40
 Re: one more time in reply to Jason, 11-05-2001 13:53:48
If you are looking to build a big motor. I had some new cyl. blocks casted. Both U and G styles, you can make them 5.75 if you want, with " PRESS IN SLEEVES ". Give me an e-mail if interested. Glenn
Jeremy Fiorelli
11-07-2001 21:23:47
Jason
From what I've gathered talking to people about the 800 blocks on the four cylinder crank case it's easier to bore the origanal blocks out and re-sleve them to 5.5". You can bore the 800 blocks to 5.5 but 5.4 is really as far as you want to go, the bores aren't very thick. The 800 blocks are bolted on different, and are longer. Rods are just another problem. The biggest problem is most rules don't allow 800 blocks and that is an easy rule to add to get rid of a tough MM. Stock 800 blocks and stock g crank 5.319" X 6" is 533CID incase you wanted to know.
Jeremy Fiorelli
Jason
11-08-2001 04:57:28
 Re: Re: one more time in reply to Jeremy Fiorelli, 11-07-2001 21:23:47
Thank you Jeremy and Mike, I appreciate all the info I can get. No matter what brand or message board I post on.
No Oliver Guy
11-05-2001 15:11:05
Stick with Olivers and Waukeshas and leave us alone.
Mike
11-07-2001 09:05:08
 Re: Re: one more time in reply to No Oliver Guy, 11-05-2001 15:11:05
I guess I'm missing something- why shouldn't Jason ask questions about Molines on the Moline board? I could understand your comment if he was asking it on the Oliver board (although I own both, and have never bragged about the Waukesha in comparison to Moline engines)
Jason
11-05-2001 15:44:52
No Oliver guy, Keep dreaming about owning an Oliver and mind your own business!
Jason
11-06-2001 11:08:27
 Re: Re: Re: one more time in reply to Jason, 11-05-2001 15:44:52
All you guys bashing olivers are showing your true mentality. To bad you guys REALLY DONT know anything, other then how to run your mouth and hide your names.
NO Olivers
11-06-2001 06:12:41
Looks like you are getting the help you need.
KB
11-06-2001 18:49:45
 Re: Re: Re: Re: one more time in reply to NO Olivers, 11-06-2001 06:12:41
And for the rest of us who would be interested in knowing the answer and suggestions to the original question, well you guys have shown why parents should keep closer tabs on their kids' activities on the net.
