Minneapolis-Moline Z
Ned Ryan
09-08-2001 09:44:37
I have purchased a MM, I have been told it is a model Z. It has the wide front end, not tricycle. How can I find the serial numbers of this tractor? Where is the number located.
Any other information would be greatly appreciated.
Thank you
Ned Ryan
BMG
09-09-2001 18:07:26
 Re: Minneapolis-Moline Z in reply to Ned Ryan, 09-08-2001 09:44:37
Ned,
Look for the tractor serial number plate on the right side of the trans housing above the belt pulley and below the hand clutch lever. There will also be a serial number tag on the engine but only the id plate on the trans will tell you much about what you have and what year it was made. If you post the numbers here we can tell you what you have.
Brian
