Shuttle Shift ?????????
COWBOY
08-28-2001 06:47:30
What is a Shuttle Shift???
How does it work?
It it a Torque Amplifier, or a forward/reverse ???
Mike M (WA)
08-28-2001 08:43:23
 Re: Shuttle Shift ????????? in reply to COWBOY, 08-28-2001 06:47:30
They're generally a forward/ reverse lever, where you can change direction without the clutch. I had an AC D-14 with one- had a neutral in the middle. You usually find them on industrial tractors, to use with a loader. They are basically the same as a torque amplifier, but instead of direct and low, its direct and a reverse gear. I think most have a neutral detent in the middle, though, so you can stop the forward motion of the tractor before going into reverse.
