Modern numbers for steering U-joint
QTRHOSS
07-31-2001 12:18:09
Does any one have a new part number (spicer, precision, or like) for the u-joints in a 51 M&M U LPG steering shaft. The LPG unit uses 3 u-joints to get around the tank.
The closest that I can get is a is a Spicer 5-92X. The caps are the correct size (.969") but the distance across the X is about 1/8 inch too long (should be 2.15"). Can anyone help with a correct modern part number?
I have about any part store chain availble to me but they look like a deer in headlights when I tell them what I need the u-joint for.
Kelvin
07-31-2001 20:55:50
 Re: Modern numbers for steering U-joint in reply to QTRHOSS, 07-31-2001 12:18:09
My ZB uses regular 6n universal joints. (or is it N6) I have gotten them through NAPA and Tractor Supply Co. at different times. I think my friendly neighborhood John Deere dealer helped last time. I don't know why your U LP should be oddball, but it might.
MMman
07-31-2001 18:40:32
Boston Gear UJS-16 This is the entire coupler, not just the U-joint. Should be available through an industrial supply house.
QTRHOSS
07-31-2001 20:06:12
 Re: Re: Modern numbers for steering U-joint in reply to MMman, 07-31-2001 18:40:32
Thanks! I was hoping to just replace the joint because I need all three, but as long as I can tighten the steering, I will be happy.
-QTRHOSS-
