UTS PTO
Bob
07-30-2001 13:28:36
My power takeoff bar will not move. I removed the pins, the tension cap and spring, magnetized screwdriver lifted the ball. still will not move in or out.Detents look clean etc. There is a metalic sound when I attempted to push the rod in. Any ideas appreciated.
Kelvin
08-02-2001 20:18:44
 Re: UTS PTO in reply to Bob, 07-30-2001 13:28:36
With the engine off, pull the lever as you turn the pto shaft. it should line up and engage within a full turn or so.
If it doesn't, Don't know what the problem is. but its not hard to remove the assembly and inspect it. Its all contained in that rear cover except the shaft that runs up and fits the splines on one of the transmission shafts.
Oh, and either stand the tractor on its nose, or plan to catch about 12 gals of transmission oil.
Bob
08-03-2001 05:09:01
 Re: Re: UTS PTO in reply to Kelvin, 08-02-2001 20:18:44
Thanks, and 12 GALLONS!! Geez I thought the JD A held a lot. I will probably drain it first, then remove that cover this weekend as I have tried turning it by hand (easy to do) and pulling at the same time. My machinst neighbor said he could get it, his dad had one, but no way. Bob
