UTS Starter removal
Bob
07-19-2001 04:38:45
Help, the book says when puting it back make sure the hole and bolt line up, I have the bolt out, scrapped the paint away around the starter, tugged, pulled, and hit it with a rubber hammer. What is next, short of causing damage? Thanks for your help, Bob
RM in Ont
07-20-2001 11:21:18
 Re: UTS Starter removal in reply to Bob, 07-19-2001 04:38:45
There is probably rust holding the starter in the hole. Spray some of your favorite penetrating oil around where the starter goes in. After that soaks in for a while, try bumping the starter every direction with your hand. Also try using a bar of some sort to pry it forward, but use caution as it is easy to break a chunk out of the cast iron of the starter.
