Mm ub value
R, CLAWSON
07-16-2001 04:12:03
am looking at a ub in pretty rough shape but it runs pretty good and its a deisel,has great tires on rear but front tires are junk.they are dry roted bad.it needs a lot of tlc.its a narrow front end.they pulled it last year and they said it weighed 5800 about.all metal is there but its rough.they want 2000 for it .this is my first tractor and i dont want to bite off more than i can chew.what do you think thanks;
Unimog
07-16-2001 20:10:00
 Re: mm ub value in reply to R, CLAWSON, 07-16-2001 04:12:03
The UBU was made in 1954-55 with total production
of 1041 units. For your first tractor I would pick
a gas engine model. Parts for older MM diesels
are getting hard to find and afford. The 2000 cost
seems too high for the condition. Tires are an
easy fix but you can spend a lot of time and $$
on sheet metal. Can you repair sheet metal or will
you farm it out. All this also depends on what your use will be. Is the tractor for show, pull
on a user. Take your time and look around at a few
others. Good luck either way.
Unimog
