Problems on a 2270 (1355)
Gary
05-13-2001 05:29:41
I just bought a White 2270 seems to work fine but
the hydraulic pto clutch runs all the time. The guy that I got from says pto seeps oil into the rearend and you have to drain it every once in a
while. Any ideas?
What are the biggest problems with these tractors?
Thanks in advance
Dwight Murphy
07-15-2001 07:21:03
 Re: Problems on a 2270 (1355) in reply to Gary, 05-13-2001 05:29:41
Gary, if this is the same closed center hydraulic system used on the 55 series Olivers it may have a small crack in the pan that seperates the hydraulics from the rear end. I had a 2255 that would do that. Good luck
