UTU gearbox oil
steve pavlat
04-26-2001 20:43:06
Anyone know what weight and how much oil goes into the gearbox on A UTU moline?
RM in Ont
04-28-2001 06:47:09
 Re: UTU gearbox oil in reply to steve pavlat, 04-26-2001 20:43:06
The rearends take 13 gallons of gear oil. I use the 80/90 in all mine. I think they may have used the 140 weight when they were made. If I have seals that leak with the lighter oil, I replace them. They usually need replacing anyway.
Steve Pavlat
04-29-2001 09:35:11
 Re: Re: UTU gearbox oil in reply to RM in Ont, 04-28-2001 06:47:09
Thanks for the information,I didn't thank it was that much. I replaced the seals and was thinking of changing the oil,but at that cost I'll just add some.How do you know when its full? What is the full mark? Thanks, Steve.
Kelvin
04-29-2001 12:14:56
 Re: Re: Re: UTU gearbox oil in reply to Steve Pavlat, 04-29-2001 09:35:11
There is a check plug on the right side of the tractor behind the belt pulley, about 4-5 inches above the bottom of the transmission. on level ground, if the oil is up to that hole, it is full.
I usually take the 3-corner plate off the trans. cover to fill mine.
