Twin City MM wheel weights
Jim Patterson
03-30-2001 22:57:30
The Twin City 21-32 (FT) and Twin City MM FTA tractors, I just picked up had a bunch of misc parts with them, that was part of the deal. I have one rear wheel for a rubber tire that has a solid center with little clamps to hold the rim to the center, It is painted red, It has these numbers cast into the center MM and FT-715. I'm assuming it is for the TC 21-32 FT, but that tractor has spoke wheels that were cut and a rubber tire rim has been welded in. Did this rim come on this tractor or is it off of some other year.
Also I have a set of wheel weights on the spoke rims of the TC 21-32 it is cast with p/n KT-657 and MM, is this off of a KT? The bolt holes are not in a square pattern, the pattern is more rectangle about 14 3/4" x 8" It looks like these will fit my 1962 4 Star Super if I use only two of the holes. I would like to find the correct ones that will go on a 4 star, I will trade these for those. Does anyone need a rim like the one listed above, I also need steel wheels for the same.
Thanks- Jim Patterson
Jim Parisot
03-31-2001 21:17:13
 Re: Twin City MM wheel weights in reply to Jim Patterson, 03-30-2001 22:57:30
Jim, I think I can help you a little. I would imagine the KT-657 weight would have fit a KT-KTA. It also is the right weight for the earlier U Standards with the 29" wheel center and the earlier ZTU's with the cast wheel centers. Would be interested in a trade if you're not too far away. Where you at?
Jim
Stacie Sinn
02-27-2002 13:43:59
 Re: Re: Twin City MM wheel weights in reply to Jim Parisot, 03-31-2001 21:17:13
I am looking for fenders for a 1931 Twin City FT 21-32. I am not having any luck so far and would appreciate any information in finding the fenders.
Thanks, Stacie
