Minneapolis moline ztu questions
lance peters
01-19-2001 18:10:20
I need some info on a ztu serial number 569170.Engine3 5/8x4 1/2 4cyl modle re 56230.Has pto power lift belt pulley assembly no belt pulley round fenders,cast iron steering wheel.1 flathead headlight mounted cultivator square gas tank,red nose,gas tank rusted out,battery box rusted out,1 wheel is not mm.first questionhow rare are cast iron steering wheels?the steering wheel has 6 spokes.what year is this tractor?did this tractor have a mm emblem on the grille?how much is this tractor worth?has good sheet metal
Jim Parisot
01-22-2001 11:19:30
 Re: minneapolis moline ztu questions in reply to lance peters, 01-19-2001 18:10:20
Lance,
Your tractor is pretty typical of the way we find them. I think the steering wheel found it's way unto your tractor if indeed that's what it is - a war time unit - as your tractor is an early '41 and unless they re-wrote the history books the Japs didn't bomb Pearl Harbor till Dec. 7. It's worth something alright, but not a whole lot. As for the tractor, it's worth a few hundred dollars, certainly less than a grand the way you describe it, probably about half that or less. The early Z's and U's had that emblem on the grill, but I don't know the cut off date. Take my advise, jump on Pete's offer.
Jim
Pete Brandel
01-21-2001 09:18:50
Lance, The serial number indicates it is a 1941 model.I do have a tractor just like this that I am parting out that has bad sheet metal but good rims and other parts.I also have a belt pulley.I am located in southcentral Minnesota.If there is anything you need for this let me know as I can ship small parts UPS.Thanks,Pete Brandel,RR3Box241A,New Ulm,Minnesota.56073 (507-354-5214)
Lindsey
01-20-2001 18:23:28
Lance
First, the cast steering wheels are not rare. The cast steering wheels were sent out on many of ZT tractors during the war, as rubber was in demand. Worth of your tractor depends on what else is wrong, or right with it. Is it stuck, what do the rims and tires look like. As a whole I would guess you could get around $250 to $300 for it, maybe a little more if not stuck. It really depends alot on how bad someone wants it.
