NATPA rules
Jeremy Fiorelli
10-27-1998 17:33:50
I was wondering if anyone had any information (from the factory) for engine replacements. I'd like to have information showing the 336 and 403 engines as replacement engines for the U and other tractors then they would be legal in Division II with the bigger engines. It would be nice to be able to use 220 pistions in my Z and still be able to pull in Division II. I'm a little short on hp in the 5500lb class on a good hard track the DC and CC cases with the 4" pistions and a propane head have a little more power.
TC & MM tractor and pulling!
Link
Todd Markle
10-28-1998 06:35:43
 Re: NATPA rules in reply to Jeremy Fiorelli, 10-27-1998 17:33:50
: I was wondering if anyone had any information (from the factory) for engine replacements. I'd like to have information showing the 336 and 403 engines as replacement engines for the U and other tractors then they would be legal in Division II with the bigger engines. It would be nice to be able to use 220 pistions in my Z and still be able to pull in Division II. I'm a little short on hp in the 5500lb class on a good hard track the DC and CC cases with the 4" pistions and a propane head have a little more power.
: TC & MM tractor and pulling!
:>Link
Where can I find the NATPA rules? I havent seen them published in the Hook for a couple of years. At that time I didnt see anything that
prohibited using 403 blocks on a U. I visited the above link and they dont have the rules there
either. I have never been to an NATPA pull
because I dont know if my tractor is legal.
Jeremy
10-28-1998 13:47:07
 Re: Re: NATPA rules in reply to Todd Markle, 10-28-1998 06:35:43
: : : I was wondering if anyone had any information (from the factory) for engine replacements. I'd like to have information showing the 336 and 403 engines as replacement engines for the U and other tractors then they would be legal in Division II with the bigger engines. It would be nice to be able to use 220 pistions in my Z and still be able to pull in Division II. I'm a little short on hp in the 5500lb class on a good hard track the DC and CC cases with the 4" pistions and a propane head have a little more power.
: : TC & MM tractor and pulling!
: : http://members.tripod.com/~Fiorelli
: Where can I find the NATPA rules? I havent : seen them published in the Hook for a couple : of years. At that time I didnt see anything that
: prohibited using 403 blocks on a U. I visited the : above link and they dont have the rules there
: either. I have never been to an NATPA pull
: because I dont know if my tractor is legal.
The 403 is legal in division III, IV, V but not in I and
II if their is information showing the 403 engine
as a factory replacement engine for the 283's I think the 403 would be legal for division I and II.
I'm sure your tractor is leagal, it is just a question of what division you would be in. Here the NATPA
will let you get away with alot the first time.
They just tell you what needes to be changed for the next pull they wont let you break the rules the secound time. My 21-32 was having problems meeting the drawbar hight, their rules for division I
only alow a 16 inch hight and my 21-32's is 18 but I found out it is at the point of hook and you have to use a clevis so I was able to make the drawbar hight
but the cement in the rear rims is illegal.
I don't know of a place on the net that has the rules and a frined has my copy so I can't give them to you. The NATPA home page has shown the rules befor but they werent their very long. I'll see if I can find sout some information.
Joe Leising
10-28-1998 16:00:39
 Re: Re: Re: NATPA rules in reply to Jeremy, 10-28-1998 13:47:07
: : : : : I was wondering if anyone had any information (from the factory) for engine replacements. I'd like to have information showing the 336 and 403 engines as replacement engines for the U and other tractors then they would be legal in Division II with the bigger engines. It would be nice to be able to use 220 pistions in my Z and still be able to pull in Division II. I'm a little short on hp in the 5500lb class on a good hard track the DC and CC cases with the 4" pistions and a propane head have a little more power.
: : : TC & MM tractor and pulling!
: : :>Link
: : Where can I find the NATPA rules? I havent : : seen them published in the Hook for a couple : : of years. At that time I didnt see anything that
: : prohibited using 403 blocks on a U. I visited the : : above link and they dont have the rules there
: : either. I have never been to an NATPA pull
: : because I dont know if my tractor is legal.
: The 403 is legal in division III, IV, V but not in I and
: II if their is information showing the 403 engine
: as a factory replacement engine for the 283's I : think the 403 would be legal for division I and : II.
: I'm sure your tractor is leagal, it is just a question : of what division you would be in. Here the NATPA
: will let you get away with alot the first time.
: They just tell you what needes to be changed for : the next pull they wont let you break the rules : the secound time. My 21-32 was having problems : meeting the drawbar hight, their rules for division I
: only alow a 16 inch hight and my 21-32's is 18 but : I found out it is at the point of hook and you have to : use a clevis so I was able to make the drawbar hight
: but the cement in the rear rims is illegal.
: I don't know of a place on the net that has the : rules and a frined has my copy so I can't give : them to you. The NATPA home page has shown the : rules befor but they werent their very long. : I'll see if I can find sout some information.
On the NATPA home page there is an e-mail address for the NATPA secretary. If you e-mail them and request the rules they will try to snail mail you a copy. Bear in mind that the NATPA is a national organization and they get many requests a day so it may take a while for a response, but they are wonderful people and will try to help.
Old Abe
10-28-1998 21:32:38
 Re: Re: Re: Re: NATPA rules in reply to Joe Leising, 10-28-1998 16:00:39
: On the NATPA home page there is an e-mail address for the NATPA secretary. If you e-mail them and request the rules they will try to snail mail you a copy. Bear in mind that the NATPA is a national organization and they get many requests a day so it may take a while for a response, but they are wonderful people and will try to help.
That's how I got mine. I believe they are going to be voting on Div III and IV rules next month. There is a typo error in the email address on The Hook's web page. This is the correct email address for NATPA: [email protected]
Received mine in about one week after I made the request.
Jeremy
10-30-1998 15:27:37
 Re: Re: Re: Re: Re: NATPA rules in reply to Old Abe, 10-28-1998 21:32:38
: : : On the NATPA home page there is an e-mail address for the NATPA secretary. If you e-mail them and request the rules they will try to snail mail you a copy. Bear in mind that the NATPA is a national organization and they get many requests a day so it may take a while for a response, but they are wonderful people and will try to help.
: That's how I got mine. I believe they are going to be voting on Div III and IV rules next month. : There is a typo error in the email address on The Hook's web page. : This is the correct email address for NATPA: [email protected]
: Received mine in about one week after I made the request.
Thanks, I sent them an e-mail and asked for a copy of the rules and if I could put their rules on my home page. If I can I'll post a message here so everyone can see the rules.
