Re:what year is it?
ROSCOE RICHARDS
11-28-2000 10:37:12
I HAVE LOCATED A MM.ON THE TAG ON THE FRAME IS MODEL 4030 SERIAL 02007461.THIS IS A LP VERSION.
IT HAS A DECAL GB ON THE HOOD.WHAT YEAR IS THIS.
I CAN NOT FIND THIS SERIAL NUMBER ON A GB. THANKS ROSCOE
Jeremy Fiorelli
11-28-2000 20:41:09
 Re: re:what year is it? in reply to ROSCOE RICHARDSON, 11-28-2000 10:37:12
I'm guessing it is a late 54 or early 55 from the engines serial number you gave us. Get us the tractor serial number from where BMG said to look.
BMG
11-28-2000 12:02:19
It appears you've found a GB LP with a 403 engine. The serial number you gave is from the engine ID plate. Check on the RH side of the transmission housing near the belt pulley for the tractor serial number tag.
Brian
