Water pump shaft
Rocky
10-08-2000 19:00:19
I am working on a U model MM. I need to replace the water pump shaft. It has a
distributor and a hydraulic pump. I have removed the water pump impeller and the hydraulic pump. Do I need to remove the distributor?
galen
10-08-2000 20:32:04
 Re: water pump shaft in reply to Rocky, 10-08-2000 19:00:19
Yes you need to pull the distributor. Once all that is out of the way you will have to drive the shaft out of the drive gear. If your's is tight and doesn't bump right out , put a nut or something on it so you don't have to rebuild the threads as I got to.
