Mm u
Dave S
08-29-2000 08:24:52
I just purchased a 51 model u standard.
It has a cracked exhaust manifold,I was told
a 2 peice manifold from a m5 will work,is this
true? the engine runs good and we plan on using
it in antique pulls. Also the engine is 41/4x5
could someone tell me ho many cubic inches this
is and how many bottom plow it could pull.
galen
08-29-2000 14:17:59
 Re: mm u in reply to Dave S, 08-29-2000 08:24:52
You may want to check rules on where you pull before you put the 336 manifolds on. Some areas state for stock pulls must have original manifolds. I don't know where all that holds true or if the 336 manifold could be considered a update replacement. They do fit as I have 336 manifolds on a KEF engine I'm rebuilding.
philo
08-29-2000 12:48:42
I believe the information about the m5 manifold is correct. I put one on my Gtb when it was rebuilt and the two peice configuration allows the air to remain cooler going into the motor. The u motor was 283 cubic inches. The U was rated at a 3-4 plow tractor, I tend to think three is closer to the mark given the clay based soil where I am from.
philo
