Minny
Mo Plows
Matt Timerman
08-07-2000 20:04:36
Need help identifying a set of trailer plows and finding points for it. The set I have is a Minneapolis-Moline with 3 12" bottoms. It has two spoked front wheels that are slightly offset from each other. The rear wheel is kicked off at a 45 degree angle. It has roughly a 50" track width. It is made of I-beam rails that curve down to the moldboard. It has a fixed ring type hitch. It is hydraulicly raised and lowered and has a lever to adjust the depth of the front bottom. The points are held on by one bolt and an eyebolt that attaches to a tab on the back of the point. The only info I can find on the plow is on the hydraulic lift frame. "AF 32" and "9376" is found stenciled upside down onto this frame. There is also some stenciling near the tail wheel but I can't make it out. I can e-mail a picture if it would help. Any help to identify and find points for this machine would be greatly appreciated.
Fred Phillips
03-16-2001 20:20:59
 Re: Minny - Mo Plows in reply to Matt Timerman, 08-07-2000 20:04:36
Hello,
I also have some Moline Plows, (2) are of the "AF" series. One is a 2 bottom on steel with MNP-142, eastern type soil bottoms, and a mechanical lift.
The other is 2 bottom with CY 142 bottoms, on rubber with an ydralic lift. The ring on the front is for a spring loaded hitch mounted on the tractor, this disconnects when a rock is struck.
The Minneapolis-Moline website is:
www.Minneapolis-Moline.com
Lots of help here.
Fred Phillips
