U-moline
Tommy Hicks
07-02-2000 14:47:11
We just purchased a 1950 u moline tractor we have the serial number and the model number, It is run off of propane. we are trying to figure out all we can about this tractor, engine info and everything else could you help us out?
serial number: 06110214
model number 283B-4
Thank you in advance for all your help. Once again our email address is [email protected]
Thank you ,
Tommy an Kim Hicks
Roger
07-04-2000 06:12:47
 Re: u-moline in reply to Tommy Hicks, 07-02-2000 14:47:11
I think what you are listing is the engine sn. We can not tell you very well the year from this no. You need the tractor sn. which is located on a plate on the right side (as you sit on the tractor) of the transmission case. It is behind the pulley, if so equipped, and kind of below the hand clutch.
Best of luck
Roger
