Unobtainium
rogerd
05-01-2000 14:31:44
My AGCO dealer sez the hydraulic pump shaft oil seal for my ZAU is made of unobtainium!
Since the Z and several others had a common setup for hydraulic pump, I thought others have probably already found a way around fixing the automatic transfer of oil from the hydraulic reservoir to crankcase. Thought maybe somebody might have a part number or a supplier that has a solution. 'Taint AGCO in Ashland Ohio!
Thanks for any advice or assistance!
Corey
05-02-2000 07:31:55
 Re: unobtainium in reply to rogerd, 05-01-2000 14:31:44
I bought one at my agco dealer a few years ago. If you have the old one, you can cut it out of gasket material. I have done that and it has worked fine. I assume you are referring to the traingular shaped ont that has three holes in the middle.
jeff
05-01-2000 17:31:15
Call Welters 417 498 6496
rogerd
05-03-2000 07:27:43
 Re: Re: unobtainium in reply to jeff, 05-01-2000 17:31:15
Will do. Thanks!
rogerd
05-04-2000 15:42:11
 Re: Re: Re: unobtainium in reply to rogerd, 05-03-2000 07:27:43
They have it. Parts are on the way to papa.
Thanks again.
