Minneapolis Moline Tractors Discussion Forum
MM 705--MF 97
Chief 83
05-16-2008 09:34:49
I'm trying to find a fuel sending unit (diesel) for my MF 97 manufactured by MM. Local MF dealer can't locate one. I've posted on the MF board but thought someone here might have a source.
Thanks,
Curt Cooke
05-16-2008 12:49:56
 Re: MM 705--MF 97 in reply to Chief 83, 05-16-2008 09:34:49
I don't have a source for an original but I might suggest you get a cheap gauge and sender set from JC Whitney for about $30 and see if just using the new sender will work for you. If not, you can use the gauge that comes with the set. The only problem with their gauges is that they are not weather resistant and will ultimately fail.
