Like JT said, it's just nuts and bolts! Minnie engines are pretty simple...The one thing I'd say, is make sure your machinist knows what he's doing. I had a set of HD800 blocks bored one time for bigger pistons - put the motor back together myself and fired it up on a well... Ran great for 5-6 minutes actually working (after I'd let it warm up good), but then pulled down and stopped with a big squeak!! Locked down tight. Tried it again a few hours later - it was free! And started like a new overhaul! But then pulled down and stopped just like before. Long story short - the machinist had sized the bores ever so slightly too small and the pistons would get too tight when really hot and lock her down. Complaining to the local MM guru who knew them as well as the factory guys could have known them - and he just said, "yeah - I only take my machine work to one guy - and he knows exactly what I expect - and I never have to worry if it's right or not...". Apparently, he sized them just a thousandth or two (or some amount - I'm not sure) extra large... Howard
