Minneapolis Moline Tractors Discussion Forum
pto clutch question
chuckb
05-10-2008 17:58:18
i have a 1964 jet star 3. When i engage the pto it takes very little effort.and when it does engage it wont turn my bush hog fast enough to cut. I looked at my I&T and and did what it said do,which was to push in the pin and turn the big nut until it clicked and recheck.it feels like it has a pretty good snap now.The book calls for about 65 lbs so i put my fish scale on the lever and it engaged at about 45 lbs.question is,do i go ahead and replace the 5 clutch disk while theyre exposed or put everything back together?
MMDEL
05-11-2008 08:30:44
 Re: pto clutch question in reply to chuckb, 05-10-2008 17:58:18
Fish scale should be OK, unless you don't catch fish that big and your scale doesn't go that high. The MM shop manuals show using a common spring scale to check the lb.s of force on different applications. Take your measurement at the very top of the lever.
MMDEL
chuckb
05-10-2008 19:38:59
sounds like what you guys are saying is reguardless of the disk thickness i still should be able to adjust the snap and put it back together.Is there a better way for me to check the snap other than a fish scale? 65 lbs seems like it will be very hard to engage.also is there a certain thickness the disk should be?
MMDEL
05-10-2008 19:22:46
You got a whole lot more taking apart to do if you want to replace clutch plates. Which includes taking the hyd pump off and pulling the PTO drive out the rear. Better give it another notch on the adjustment. Get it up to specs. If it's not tight enough and it keeps slipping a little, maybe not enough that you notice it. It will warp the plates, then you got more problems.
MMDEL
Curt Cooke
05-10-2008 19:03:02
I suppose I'm a piker but I'd put it to the test as is and if it fails again, then I'd replace the discs. My guess is that you'll be OK the way it is.
