Minneapolis Moline Tractors Discussion Forum
M-M Z clutch linkage parts
Tom/Idaho
05-09-2008 07:49:09
1952 Z # 00800427. After looking thru the side port I can see the throughout bearing and "fork" that moves it need to be replaced. Does anyone have a parts book that can give me the part number and proper name so I can start calling? Also, where would be a place to start lookin? Thanks for any assistance, Tom/Idaho
BMG1
05-09-2008 16:43:33
 Re: M-M Z clutch linkage parts in reply to Tom/Idaho, 05-09-2008 07:49:09
Tom,
Your 1951 ZAN should have a hand clutch. Repair catalog R-1072B lists the following:
10A1763 Shifter Yoke complete (this is the collar - brass I think - 2 halves bolted together)
JT5180C Clutch shifter fork (JT180C) with set screw (this is the fork mounted to the clutch shifter shaft going through the bell housing area)
These parts were also used on the ZT series tractors so finding them used shouldn't be too difficult. Your hand clutch also has the over center mechanism that looks like a 4 legged spider. Do you need that info also?
Brian
