Minneapolis Moline Tractors Discussion Forum
What tractors have same rear hubs (38 rims) as a G1000?
Jeremy L
05-07-2008 05:34:08
What tractor models/makes have the same rear wheel hubs as a G1000 (38" rim hubs)? Or, where can I find a set of these hubs? I currently have hubs that fit the 34" rims but no longer want 23.1 x 34 tires, I want 20.8 x 38 tires instead but understand that I need to change my hubs in order to do so.
Dodds Racing
05-08-2008 15:22:21
 Re: What tractors have same rear hubs (38 rims) as a G1000? in reply to Jeremy L, 05-07-2008 05:34:08
We have a set of center hubs and the cast centers for the 38 rim from a G1000 vesta that we will sell.Have already sold rims.
Jeremy L
05-09-2008 05:53:24
 Re: What tractors have same rear hubs (38 rims) as a G1000? in reply to Dodds Racing, 05-08-2008 15:22:21
Where are you located and how much? Would you consider trading straight up for our cast centers?
Jeremy L
05-08-2008 05:41:35
Sorry everyone but I should clarify that it is the large cast piece which connects the actual hub on the axle to the rim on the tire of the tractor that I am looking for.
My parts manual shows three different cast pieces (as noted above), one for 30" rims, one for 34" rims and one for 38" rims. I know that the 34" piece I have will not fit 38" rims because they are an entirely different setup. The ones I have are wide/thick and are designed to fit tighter into the rim so that the cast piece actually carries the weight where as the 38" cast pieces are the more traditional type which are thinner and use several metal extension pieces that reach out to hold onto the nubs/bumps on the rim. The extension pieces are bolted to the cast piece/center hub in such a fashion that they are centered over the connection point of the hub to the axle to prevent any moment/torque on the cast piece but the 34" cast pieces are not like this (they have little metal pieces that just hold the rim in against the cast piece/center hub) since they actually sit tight to the rim and carry the load.
Sorry for the long winded explain and thanks for all your feedback.
R.D.F.
05-07-2008 11:55:19
Hi, on that G1000 you shouldn't have to change the hubs, the 34" and 38" bolt on the same, the exception is if taper lock hubs were used such as the ones on 9 and 1050's, Dale
freddy
05-07-2008 07:03:28
there have been a lot of A4T-1600 junked and they had used 18.4 - 38 too
Shep Va
05-07-2008 06:15:29
I might be interested in your 23.1 x 34s, where are you located?? E-mail me if you are close to Virginia and want to sell the wheels and tires.
Luke is correct any of the later model tractors, the G-950, G-1050, etc will have the taper lock hubs that will fit. The G-955 and G-1355 have the Oliver style rear wheels so they will not work.
Clint Youse MO
05-07-2008 06:12:57
They make a set of step up rims to do just that check with your local ag tire store they should be able to find them or the tractors that Luke mentioned most of them had 18.4-38 on them my G900 evene has 16.9-38
Shep Va
05-07-2008 06:18:57
 Re: What tractors have same rear hubs (38 rims) as a G1000? in reply to Clint Youse MO, 05-07-2008 06:12:57
Check around and see what the price on the step up rims will be, I checked into that when I was moving my 23.1 x 30 tires up to 23.1 x 34 and it ended up being cheaper to buy the entire hub and wheel with used tires on them then to buy the step up rims and then put new tires on the new rims.
They make the step up rims to do this job, but they are not cheap from what I have seen.
Luke Miller
05-07-2008 05:49:47
I would think that G1000, G900, G950, G1050, and Maybe M670 would be the same. Someone correct me if I am wrong. I dont know if the axle size is different on these tractors or not though.
