Minneapolis Moline Tractors Discussion Forum
Magnito impulse
bruce granger
04-29-2008 06:24:37
I am working on a UTS. What is the proper impulse timing? The impulse coupling has two keyways, 20 and 35 degrees.
FM mags
04-30-2008 12:39:44
 Re: Magnito impulse in reply to bruce granger, 04-29-2008 06:24:37
Actually neither one. The Fairbanks Morse mags for U series MMs were suppose use a 25� impulse hub and UB drive cup for CW rotation. You might try the 20� as only off 5� but if it doesn't start or work well I probably have the correct one you need. What type fuel or model engine?
Bruce Granger
04-30-2008 13:40:50
 Re: Magnito impulse in reply to FM mags, 04-30-2008 12:39:44
When cleaning the mag I have now found a 35 deg mark on the mounting flange. I have no idea if this is the origional mag. I do have a 25 deg impulse hub from another mag. This is my brothers tractor. He gave me the serial number as UTS 31438I. Other numbers were 00610495 and 10808327. The engine is a vintage with one piece head, I believe it of a vintage for tractor fuel.
FM mags
04-30-2008 21:33:44
 Re: Magnito impulse in reply to Bruce Granger, 04-30-2008 13:40:50
I should have asked mag brand and model number but FM was only ones I knew of made some impulses with dual keyways so figured that's what you had a FM-K,O,OH,OR,XOR model. If a Fairbanks Morse mag they showed for all mags on all U, UT, UTS, UTU to use 25� impulse. However Fairbanks Morse shows using a 35� impulse on the 283-4A power unit engine mag. Bosch and Wico both showed using a 35� impulse for their mags for MM U series and 283 applications. If the engine is still stock and not high compression try 35� but be aware it's not what was recommended with a Fairbanks Morse mag. If it's going to be souped up with higher compression 20� might be closer.
