Minneapolis Moline Tractors Discussion Forum
MM Plow Drill Questions
JKC
04-26-2008 11:48:59
I am looking for information on what I believe to be a somewhat rare MM implement from the 1950s. It is a Moline-Monitor Plow Drill, Model 10-6 P3, about 5 feet wide, designed to attach to a soil packer, with both then attached behind a 3 or 4 bottom plow.
Here are my questions:
1. What years were these drills made?
2. Are they somewhat rare to find?
3. Does anyone have any history of these you would be willing to share, such as what part of the country they were mostly used in, in what kind of crop ground, under what conditions, etc.?
Any information you could share would be very much apprecitated. Thank you.
newfarmer9
04-27-2008 07:55:04
 Re: MM Plow Drill Questions in reply to JKC, 04-26-2008 11:48:59
I wouldn't call them rare, but there are definetly not that many around.
Jerry Mandt
04-27-2008 07:07:20
A 10-6 should be 10 runs spaced 6" apart. Goes behing a 4-14 plow. These were most likely made in the 40's and 50's as that is when we used them a lot in ND where I came from. Stubble was worked in the fall with residue left in place to prevent drifting and then the ground was pony drilled in the spring. We quit using them in the early 60's. Don't see them very much any more.
