Minneapolis Moline Tractors Discussion Forum
mm z tractor
gene watkins
04-21-2008 18:01:33
i got my tractor home today. it is a zau ser no is 0064902388. got some questions. does the hydrolics take hydrolic fluid or motor oil.what spark plugs does it take, the ones that are in now are champion j8c. doesnt seem the wright number to me. any help will be appreciated. thanks gene
Alan K
04-21-2008 20:32:11
 Re: mm z tractor in reply to gene watkins, 04-21-2008 18:01:33
You can use Auto Trans fluid like Dexron II or a light weight hyd oil ( non-detergent ) like 10w. 20w if you dont operate it in colder temps will work fine. The hyd system is separate of the engine oil but there is a vent or overflow tube that is connected to the crankcase. The J8c is the correct plug for general use I believe.
