Minneapolis Moline Tractors Discussion Forum
Impco 200 on 605 power unit
Larrys-MM
04-21-2008 17:07:45
Is there any adjustment to be made on a impco 200 with a 2 bolt flange it has a load screw but no sure were to run in ? It is on a 605 power unit that is run on LP gas . thanks Larry
LW
04-22-2008 06:37:45
 Re: Impco 200 on 605 power unit in reply to Larrys-MM, 04-21-2008 17:07:45
The screw is air bypass gor idle, the gate valve near the big low pressure lp hose is the fuel adjustment. IT has just two flats on it.
