Minneapolis Moline Tractors Discussion Forum
MM UB Hydraulic Pump - Webster
teebogr81
04-17-2008 06:30:57
Thank you in advance to all who reply to this post and to my previous posts on this subject.
I removed the webster pump and ordered the seal for it. However in dimantling the pump I ran into a little catch. Can anyone tell me how to remove the main bearing from the shaft to allow the shaft to be removed from the plate with the seal in it? Is it pressed on or am I missing something else?
Thanks again,
Tee
teebogr81
04-21-2008 08:43:30
 Re: MM UB Hydraulic Pump - Webster in reply to teebogr81, 04-17-2008 06:30:57
I figured it out. I removed the spring retainer clip and then tapped the shaft a couple times with a hammer and the bearing came right off.
