Minneapolis Moline Tractors Discussion Forum
Vickers Spool Valve - Schrocky
SWMolines
04-16-2008 10:53:51
Mr. Schrocky can I impose on you to look something up your Case 310 manual? I have found just about everything I need to rebuild my spool valves for the 2 Star but I am still a little uncertain about the seals that go around the spools at the ends. Can you look in your manual and see if it sheds any light on my confusion?
Thanks,
Keith
schrocky
04-17-2008 14:05:29
 Re: Vickers Spool Valve - Schrocky in reply to SWMolines, 04-16-2008 10:53:51
give me a few days and I will see what I can find
SWMolines
04-17-2008 14:30:29
 Re: Vickers Spool Valve - Schrocky in reply to schrocky, 04-17-2008 14:05:29
Thank you very much. Do not spend a lot time if you can not locate it. I am sure I can back into what was once there if I keep digging and asking questions. But there was nothing recognizable left in the grooves when I got the spools out. The heat of the fire had turned the seals to hard carbon that just crumbled. It is hard to believe that it was just an o-ring but that might be all that was there.
