Minneapolis Moline Tractors Discussion Forum
445 Speedometer Cable
Bog
04-16-2008 05:17:22
Hey everyone. I have a 445, but the speedometer cable is gone. Are they a special cable or caqn i get one from my local napa? I am not sure if they a wound backwards from everyting else. I have also heard the that the drive gears for these go out, is that true?
Alan K
04-17-2008 14:10:07
 Re: 445 Speedometer Cable in reply to Bog, 04-16-2008 05:17:22
Not sure where you can get one other than AGCO that would work for sure. I believe the parts book lists it as # 10A9358. Also has (10A7994) listed which is also listed under M5(diesel) and M602 (gas or diesel) for the tach/speedometer cable, 73" long. 5 Star is the same number as the 445. 4 Star Super shouws the same number also. I have heard also that the gears strip on them. Have heard that they were a "fiber" type material. Someone was or had made some up at one time I believe.
T.R.K.
04-17-2008 18:36:24
 Re: 445 Speedometer Cable in reply to Alan K, 04-17-2008 14:10:07
Delbert Schaffer (Sp?) had some of those spedometer gears at one time. He posts over on the MM website as MM Del or something similar.
