Minneapolis Moline Tractors Discussion Forum
Opinion time: Ether or not?
Molineone
04-11-2008 15:10:30
I have heard a lot of opinions on wether ether is harmful or not to diesel engines. I figured this was a good location for a few more. Fire away!
Eric Berglund
04-15-2008 06:55:01
 Re: Opinion time: Ether or not? in reply to Molineone, 04-11-2008 15:10:30
I live in Canada and have installed electric manifold pre heaters from the a4t series into other tractors including the MF 97/G 706 down to the UB diesel.As long as the manifold has a provision for a pre heater and many do.I keep good batteries fully charged and a good starter and I have eliminated the need for either starter fluid.
Just my 2 cents
Eric
yonson
04-14-2008 11:24:14
Ether is a very strong solvent & will wash the lube off cylinder walls potentially leaving them in danger of scoring when using too much at a time. On a related note, years ago an old timer told me about an incident back in the '40's when he worked as a welder for a construction outfit here in Minnesota. In the winter when it got really cold, the gas engine on their power shovel was hard to start so they would have him do it as he had figured out a way by putting a quick shot of acetylene in a couple cylinders thru the spark plug holes. One cold morning his young assistant volunteered to start the engine. A short time later there was a loud noise and my friend went out to check. The young guy had put a big shot in all six cylinders and blew the side of the engine off. True or not, makes a good story! RW
utupuller
04-14-2008 09:08:11
I used to work for a moline collector in MN and any diesel MM would have a can of ether in the tool box. I came to know molines through him and need less to say I cant picture a MM diesel with out a can. But like others said it only takes a little squirt.
JTinNJ
04-14-2008 06:03:24
I use it when needed. I don't get carryed away with it,only a tiny squrt.If it's so cold a tiny squrt will not do it,then it's to cold to be out side anyway.
LenND
04-13-2008 14:01:54
Starting fluid works great and won't hurt anything if used sparingly. Years ago we got some new White trucks with Prekins diesels in them and when it got around 20 below you had to use starting fluid plus engine heaters on all night. These were new trucks but they didn't have new engines very long. Ether scored the insides from too much use.
Moline_guy
04-13-2008 11:51:08
third party image
third party image
I think either is kind of like alcohol, if used in moderation no harm done and it gets the job done. :=)
Old, low compression, worn out diesels need a little nudge when its cold.
Molineone
04-13-2008 05:15:59
Thanks for the thoughts! Up here in MN, she gets a bit nipply and things gets difficult to start and small expolsions need to happen somehow. I guess I am still wondering why ether is so bad? Is it because it burns so hot (hotter than diesel) on a cold piston/cyinder that it causes too much additional wear and tear? I guess heres where I need the education and not the opinion. Thanks again!
LWyod602
04-12-2008 07:04:12
I usually just read all these discussions but I will interject here, I worked years for a fella who had an M602 Dizel and 2 things were required, no ether and oil changed every 100 eng hrs. That tractor lived over 9000 hrs to its first overhaul and has 6000 hrs on that rebuild. It feeds cows everyday. It has a block heater and under 45 she is plugged in, a much better choice I would say
LW
04-11-2008 17:16:22
Silicone spray works good and the engine won't hammer may not be"strong" enough if your somewhere really cold but it works good and I only use it if I absolutely have to and I despise ether.
MnM44
04-11-2008 17:39:47
 Re: Opinion time: Ether or not? in reply to LW, 04-11-2008 17:16:22
I would despise ether to if I lived where a cold snap was 35 degrees.
LW
04-12-2008 20:14:28
 Re: Opinion time: Ether or not? in reply to MnM44, 04-11-2008 17:39:47
Your not very accurate there. In 2002 we had 30 inches of snom from one strom and it didn't get above 14deg. for 7 days. It does happen but not like you get it.There calling for below freezing tuesday morning lets hope it doesn't the peaches have already budded out.
schrocky
04-11-2008 15:49:49
Well it is obvious that the newer starting fluids are not as abusive as the old straight ether, now take something very oily or greasy and spray starting fluid on it...it is one of the best portable parts cleaners available...now picture this going on inside of your engine. In my opinion if you have no other way then use it, but for me it is last resort. My 2 cents worth
Molineone
04-13-2008 05:18:20
 Re: Opinion time: Ether or not? in reply to schrocky, 04-11-2008 15:49:49
I like the oily parts cleaner, I can buy that. Thanks.
