Minneapolis Moline Tractors Discussion Forum
More MM Auction Pics
Howard H.
04-10-2008 20:17:44
Here are a few more from the MM row:
third party image
third party image
third party image
third party image
third party image
third party image
third party image
This GVI was not from the sale per se, but was for sale on a trailer nearby - it looked to be very sharp!!:
third party image
Joe Pro
04-13-2008 16:34:15
 Re: More MM Auction Pics in reply to Howard H., 04-10-2008 20:17:44
Do you have a picture of the tracotr that has them square fenders sitting next to that g1000? I would like to see it
freddy
04-13-2008 12:18:46
Howard, did you get the a4t in the picture?
ejr-IA
04-11-2008 12:25:06
Hey Howard in the sixth picture what model is that and aprox. year?Have one like that from my Grand dads day's of farming never could find on the tag what model it is.Looks just like it.
BMG1
04-12-2008 06:10:47
 Re: More MM Auction Pics in reply to ejr-IA, 04-11-2008 12:25:06
The 6th picture is probably a 21-32 based tractor. The KT and KTA had a one-piece cylinder head and a different trans/rear end. My 1930 21-32 had the numbers cast in the lower radiator tank so I'm guessing that one is probably built prior to 1930. It looks just like our 21-32.
Brian
Howard H.
04-12-2008 08:35:59
 Re: More MM Auction Pics in reply to BMG1, 04-12-2008 06:10:47
What was the family history between the KT and the 21-32?? Which came first in which years?
What is the difference between a KT and KTA??
I'll have to look at Dad's 21-32 vs the KTA I just bought to see what you mean!
Howard
BMG1
04-12-2008 17:09:35
 Re: More MM Auction Pics in reply to Howard H., 04-12-2008 08:35:59
Howard,
There really isn't much common between the KT and 21-32. The 21-32 is the predecessor to the G series (21-32, FT, FTA, GT, GTA). The rear end housing was basically the same from the 21-32 through the GTA. The 21-32 has an open or unshrouded flywheel. This was used through the GT tractor but was enclosed on the GTA. The GTB switched to a rear end/trans housing similar to the U series. The KT/MT series were the predessors to the U series. The engine design carried over to the U but the rearend housing was changed when the U came out. In 1947 I believe the U switched from the one piece head like the KT to the 2 piece head like the 21-32. The 21-32 came out in 1926. The KT came out in 1929 and is regarded as the first tractor produced after the merger by new MM management. The only real difference between the KT/MT and the KTA/MTA was the engine rpm (1,000 vs 1,150). There were several other minor differences I'm sure but rpm seems to be the real big one.
Brian
Howard H.
04-11-2008 12:59:26
It is either a KT or KTA, Twin City, I'm pretty sure. Not sure what the differences are in those. It would have been mid-20's to mid-30's.
Is there not a tag on the right hand side of the transmission case - right in front of the rear axle? Sometimes they are sort of hard to find.
Howard
M Hornick
04-12-2008 06:20:48
 Re: More MM Auction Pics in reply to Howard H., 04-11-2008 12:59:26
The 6th pic. is of a 21-32. The first of the Twin City and TC/MM tractors had the serial # plate on the left side of the tractor. Mike
J. Wondergem
04-11-2008 14:42:26
Serial number should be on the left side just behind and a little above the clutch inspection hole. Looks to be a little different color there in the picture, and that's where it is on my 21-32.
Alan K
04-11-2008 10:46:46
Awesome pictures. Didnt most U LPs have smaller tanks on them than is pictured? ( like the one beside the A4T ) Wish I could have spent a couple days there. Thanks to everyone posting pictures so we all can get a feeling of being there.
Gary in Neb.
04-11-2008 05:35:21
so how much did stuff bring? i wanted to go but could not get away.
