Minneapolis Moline Tractors Discussion Forum
9 bolt hubs for a MM G
Steve Sorenson
04-03-2008 18:21:49
Our there any hubs out there that can be made to fit a G?
Mopower
04-07-2008 17:59:33
 Re: 9 bolt hubs for a MM G in reply to Steve Sorenson, 04-03-2008 18:21:49
Got a design drawn up for a U but cannot find a cheap way to put a spline in for a G. I bought F30 hubs. Same spline.
KJY
04-05-2008 05:51:50
Give up on the 77 there Stevie???
Steve Sorenson
04-05-2008 07:38:29
 Re: 9 bolt hubs for a MM G in reply to KJY, 04-05-2008 05:51:50
No I didn't give up on my 77, I'm turning it into a div.3 puller, plus I'm starting to build another 77 for div.2.
tc-ks
04-04-2008 09:33:11
I emailed you. There is a guy in Missouri that trims down W30 hubs which are the same spline as MM G. These make nice hubs.
Cast Iron Dave
04-03-2008 18:44:42
Do not know but we had a machine shop cut out a round piece that would bolt to the eight hole G hub. We then cut the middle out of a 9 bolt rim and welded the new 8 bolt ring to the wheel. Looks just like factory made.
