Minneapolis Moline Tractors Discussion Forum
R Hood with side curtains
Loren in MN
04-02-2008 22:53:42
On an RTI, did MM ever use the hood with side curtains or were all RTI's made with the later style hood. I thought all R's had the hood style change sometime in 1949. I have seen older (1947-48) RTI's with the newer style hood. Were these most likely changed?
Thanks
MMDEL
04-04-2008 07:20:19
 Re: R Hood with side curtains in reply to Loren in MN, 04-02-2008 22:53:42
All the UTIs with Lull equipment had the sides removed.
MMDEL
Dieselbear
04-03-2008 18:52:41
I have a 44 and it has the side on the hood
BMG1
04-03-2008 16:01:58
Loren,
The RTI was the first model to implement the one piece hood for the reasons MMDEL listed. This hood was implemented with the first RTI produced in 1948. The rest of the R lineup implemented the new hood midway through the 1949 model year.
Brian
Loren in MN
04-03-2008 18:21:39
 Re: R Hood with side curtains in reply to BMG1, 04-03-2008 16:01:58
Does that mean that any RTI before 1948 would have the hood with side curtains? I have seen a very early (about 1941) RTI with the old style hood.
I have a 1948 with a poor new style hood, no loader, and was thinking of using an old style hood that I have. I've sold my 1949 RTI that had the Lull loader. It also had the new hood style.
Thanks for your help,
Loren
BMG1
04-03-2008 19:35:00
 Re: R Hood with side curtains in reply to Loren in MN, 04-03-2008 18:21:39
Loren,
Yes. Any RTI prior to 1948 should have the early style hinged and louvered hood sides. I see a lot of RTI's with the early hood but the louvered sides have been removed to allow access to the engine when an attachement like a loader is installed.
Brian
MMDEL
04-03-2008 07:04:06
I didn't look in my books to see if the first RTIs were less sides. But they were made that way because you could not open the side curtains with Lull loader and other mounted equipment. Then later they put that same hood on the ag. tractors.
MMDEL
