Minneapolis Moline Tractors Discussion Forum
M-M Z Compression Ratio
Mike Tessman
03-30-2008 09:52:21
Would like to put a higher compression head on an early Z. Don't have a parts book yet! Anyone have a head # for a gas engine that came on the later z's? Older engine is the 186. Any help would be appreciated. Thanks Mike
capt-ugly
04-07-2008 19:49:25
 Re: M-M Z Compression Ratio in reply to Mike Tessman, 03-30-2008 09:52:21
10A2647 and 10A2648 are what you need too find ;about 375.00 too 450.00 !! they really help for for pullen ; good luck
Augie
04-01-2008 11:30:09
Info here.
Ill John
03-30-2008 15:52:45
The RE226C is the highest compression "RE" head casting #. The 2 LP head casting #s start with 10A #s, they have 2 freeze plugs and the RE heads have only 1. I have a complete set of ratios in a list somewhere, I'll try to find it if you want. might try the MM site and look for head specifications there.
Mike Tessman
03-30-2008 19:54:22
 Re: M-M Z Compression Ratio in reply to Ill John, 03-30-2008 15:52:45
Thanks, that is what i needed to find out. Really appreciate the info. Mike
T.R.K.
03-31-2008 16:54:34
 Re: M-M Z Compression Ratio in reply to Mike Tessman, 03-30-2008 19:54:22
I think compression ratio info. on those heads would be on Jeremy Firoelli's (Sp?) tractor pulling website.
