Minneapolis Moline Tractors Discussion Forum
R Governor
M Jordan
03-30-2008 06:30:51
moline r wont rev up manually with throttle to high rpm and when under aload governors dont seem to working
dlp
03-30-2008 16:48:20
 Re: R Governor in reply to M Jordan, 03-30-2008 06:30:51
I take mine apart & install new bushings. The vertical rod is pulled out, hole drilled oversize about 1/2" down, & a bush is pressed in (can't remember the bushing size right now). I also had to shorten the rod to carb a little to take out slack. Seems to me like the shaft may be shimmed, but that is done when it is taken apart. Sounds like it is really worn. My UTU would throttle up but would fall flat on it's face when it started to get under a load. Did the above & it works great now. I have also rebuilt my two Z governors & they work great. Hope this is some help!
R Moline
03-31-2008 11:11:13
 Re: R Governor in reply to dlp, 03-30-2008 16:48:20
I have a good working govenor I would sell.
