Minneapolis Moline Tractors Discussion Forum
MM UB Hydraulic pump
teebogr81
03-28-2008 14:24:57
third party image
Can anyone identify this pump for me? I need to order new seals it's putting hydraulic oil into the crankcase. What is the best hydraulic oil for an old M&M?
Thanks,
Tee
lARRY O.
03-29-2008 13:33:05
 Re: MM UB Hydraulic pump in reply to teebogr81, 03-28-2008 14:24:57
There is a tag on the back side of the pump that will give you the model #. It may not be your pump seal. There is a line from your resivor to your crankcase. If the screen in the resivor gets pluged it will send the hyd. oil in to the crankcase. I have had that happen twice but diffrent tractors. Remove the side cover and clean it.
lARRY O.
03-29-2008 13:32:17
lARRY O.
03-29-2008 13:31:58
Alan K
03-28-2008 18:58:32
That looks like a Webster pump. Dont know the model for sure, I will have to do some looking. The Eaton pumps were round and the "square" ones were Websters. A guy told me years ago that when the Eaton pumps wore out they replaced them with the Webster pumps. I dont know about others but I know on the ZA ZB series if you have a different pump you have to have the triangle flange / pipe assy behind it as it is turned 1/4 turn for mounting. I use 20w non detergent in my ZA. I dont run it in cold weather and I figure if there is some extra wear it should hold up ok. Its not too thin and not too thick.
oldironman
03-28-2008 15:39:29
Seals are like bearings. They are all made by seal and bearing co and are used in all kinds of things. Most larger cities have co that sell seals and o rings. All the mfg do is buy from them and triple the price to the buyer.
