Minneapolis Moline Tractors Discussion Forum
gears hard to shift
chuckb
03-25-2008 20:28:03
I have a 1964 jet star 3 and i just changed the 11 gallons of gear oil. When the engine warms up and i put it in gear then stop with it still in gear and the engine running, it is very hard to shift back out of gear.Does anyone know what is going on here or is this the way these tractors are made?
JK2
03-26-2008 07:24:35
 Re: gears hard to shift in reply to chuckb, 03-25-2008 20:28:03
In MM tractors with an Ampli-Torque in high range (lever forward), if you are going uphill in a foward gear and push in the clutch, the overrunning clutch in the Ampli-Torque prevents the tractor from rolling backward. The same is true when backup uphill in reverse. Even if there is only a slight grade, the gears will be under pressure in those instances. If you move the gearshift lever to neutral before the tractor stops moving, you will find it shifts fairly easy. John
R Aiken
03-26-2008 02:50:04
Shift gears with the AT leaver in low range.
Alan K
03-26-2008 07:19:45
 Re: gears hard to shift in reply to R Aiken, 03-26-2008 02:50:04
I agree. I have an M5 and an M670 super and that makes shifting easier.
