Minneapolis Moline Tractors Discussion Forum
Vickers Spool Valve Rebuild
SWMolines
03-24-2008 15:06:29
I need to rebuild the Spool Valve set from a MM 2 Star Crawler. I am having no luck locating anyone in the Phoenix area that can supply the seal kit needed to rebuild the unit. Does anyone know of a good soource for seal/rebuild kits for 1950's vintage Vickers Spool Valves? If you do, let me know. I'd like to keep the original spool valve on this unit if possible.
Thanks!
schrocky
03-25-2008 16:31:56
 Re: Vickers Spool Valve Rebuild in reply to SWMolines, 03-24-2008 15:06:29
I am going to do some research but when we had dads auction the MM crawler had the same valve as a 310 Case crawler we had. I have some old Case books at my shop and if you do not get a better answer by next week I will check it out.
SWMolines
03-26-2008 06:27:46
 Re: Vickers Spool Valve Rebuild in reply to schrocky, 03-25-2008 16:31:56
Thanks!
That would be a big help. I am not even certain mine can be salvaged. I started the tear-down last night and got the first spool out. The seals look pretty simple but I still have two stuck spools. The fire and years of exposure have not been kind to this set of valves. Luckily there does seem to be some oil left in it. I'll know more once it is all apart.
