Minneapolis Moline Tractors Discussion Forum
800 power unit found
dan osborne
03-24-2008 13:31:31
Stumbled across an 800 power unit and bought it. It is not an HD however, as it has 10A4212 heads. Has a mag and an interesting starting rig. Has a shaft with a double pulley where the starter would be. Looks like a small gas engine perhaps was used to start it. Has a big 18 groove pulley used to run a grinder at an old feed mill. Set up to run on natural gas. Whats it worth? Will this thing bolt up to a GB or G6? Anybody have a starter and distributor set up for this? Unit has set for 20 years covered but is loose. Got it from the owner of the mill and he claims he ran it till he closed up.
ssss
03-30-2008 17:01:00
 Re: 800 power unit found in reply to dan osborne, 03-24-2008 13:31:31
nothing wrong with using the mag mine works great that way
JK2
03-24-2008 14:12:57
I have a pair of HD800's that had a similar arrangement for a starter. They were started by air starters. John
