Minneapolis Moline Tractors Discussion Forum
ZB live PTO clutch ?
capt-ugly
03-22-2008 12:48:49
i'm restoring a ZB in a basket ; how do i reasumable the clutch for the semi-live PTO ???
BMG1
03-23-2008 19:15:36
 Re: ZB live PTO clutch ? in reply to capt-ugly, 03-22-2008 12:48:49
Capt,
How far do you have it apart? I did a complete overhaul on one in a UBED last year. I should be able to help you out with whatever advice you need. Shoot me an email.
Brian
capt-ugly
03-26-2008 18:01:38
 Re: ZB live PTO clutch ? in reply to BMG1, 03-23-2008 19:15:36
how do i get all those springs back were they belong ??
T.R.K.
03-23-2008 18:32:18
Its been 10 years or more since I changed the disk in Granddaddy's ZB. If someone on here can scan and send you a parts book illustration that would be great because it would be quicker. There was also a section drawing of it in the I&T manual.
From what I recall: Be sure to replace the seal (Or is it 2 seals?) between the inner and outer shafts. That is where it was leaking on the clutch disk on this one.
Hopefully no one took the pressure plate assembly apart like I did. It was a real chore to put the springs and their domed caps back between the 2 end plates of the assembly. On the other hand that I probably took it apart because of all the transmission fluid on it.
If no one can e-mail you a parts illustration, e-mail me. I can copy and mail them to you.
