Minneapolis Moline Tractors Discussion Forum
minn. moline 4 star
rickyrednek
03-12-2008 07:13:24
i have a minneapolis moline 4 star and it has problems with the clutch. i have never played with one of these before and think i better get help from someone who has before i make it worse than it already is. can anyone help???
JK2
03-13-2008 13:37:20
 Re: minn. moline 4 star in reply to rickyrednek, 03-12-2008 07:13:24
If the clutch both slips and fails to disengage properly, I would suspect that either the pressure plate is warped or the pressure plate is not adjusted correctly so that it applies pressure evenly around the whole disk and pulls the plate away from the disk squarely. If the pressure plate is warped, the flywheel could also need to be refaced or replaced.
Alan K
03-12-2008 23:11:06
What's it doing?
rickyrednek
03-13-2008 05:26:39
 Re: minn. moline 4 star in reply to Alan K, 03-12-2008 23:11:06
im not sure yet. i havent driven it im just going by what my uncle and grandpa said was the reason they parked it. they said that it would slip sometimes and that itd not disengage sometimes and that the clutch was just goofy actin altogether. ill get back with u on it later. i just wanted to know if those had any common problems with the clutch
Alan K
03-13-2008 07:36:42
 Re: minn. moline 4 star in reply to rickyrednek, 03-13-2008 05:26:39
Not that I know of. Sounds like the fingers on the pressure plate arent fully disengaging. Might just be worn or it might be the throw out bearing. If it slips under load the springs on the pressure plate are probably weak. I had a ZB that the fingers were wore off.
rickyrednek
03-13-2008 11:48:25
 Re: minn. moline 4 star in reply to Alan K, 03-13-2008 07:36:42
yes but my grandfather has had it apart before and worked on it and he does it for a living and he couldnt even figure out what was wrong with it. he said that all of that is in good shape. he just said screw it and parked it when he got sick enough of it
