Minneapolis Moline Tractors Discussion Forum
piston help moline r
douglas 52
03-11-2008 09:51:28
i am in desperate need of some minneapolis moline r 20 over pistons .. and some valve seat inserts anyone can help please let me know!!! Im trying to reserect a 51 from the grave yard also needed are crank pulleys and sediment bowl respond by email or call 6166381891 or [email protected] thanks alot
Roger H MI
03-14-2008 19:07:47
 Re: piston help moline r in reply to douglas 52, 03-11-2008 09:51:28
I was hoping you would get more feed back on your pistons. I would like to know of a source for R pistons. I'am just curious if 335 pistons would work.
T.R.K.
03-14-2008 18:45:45
Hope you have found some by now. Here are some places to try:
Wendell Everett 740-922-3335 Welters 417-498-6496
These guys can help with crank pulleys too. Might be good used, though.
Pistons for Rs are tough to find. Since your are wanting .020s, I'm guessing you want to bore it. If you can find a shop that will do it, your blocks can be sleeved and you can use your old pistons. other option is to use oversize Z pistons but the Z piston won't come to the top of the bore and you loose a bit of compression. some guys get around that by running an LP head but they are tough to find and pullers are snapping up what is out there.
As far as the valve seats go, My machine shop guy always got them and put them in for me.
