Minneapolis Moline Tractors Discussion Forum
Moline steering Lube??
kirk in ks,
03-04-2008 15:54:50
How doyou grease the steering on an Moline TYpe s combine and the same question on a the early 60's tractors IE,,,. M-5 ,G-704, G-6,
is therre a fittingf under the steering post under the wheel to greease it or oil it ,
I recall the M-5's and i never saw anything that you could oil or grease under the wheel ,or in the post as when they got dry, they would rub and make a metal howling sound,
please help ok,
kirk,.
T.R.K.
03-04-2008 17:31:45
 Re: Moline steering Lube?? in reply to kirk in ks,, 03-04-2008 15:54:50
You might have to do what the old timers did on the old 3 speed column shifters: squirt a bit of oil at the top of the shaft and use compressed air to blow it on down in there where it needs to be.
P.S. I don't see a grease fitting on the steering column of Mom's M5 either. Yet the bottom line Jetstars have a grease fitting on them.
