Minneapolis Moline Tractors Discussion Forum
whats the value of a M5 Diesel???
melvin
03-01-2008 07:40:06
Hello all you MM experts,i have a chance to buy a MM M5 Diesel factory wide front,3 point hitch,has been overhauled,tin work and paint good,has 95L15 fronts and 16.9.38 rears,clean tractor,is ir worth $3500 ???thanksmel
schrocky
03-01-2008 14:20:21
 Re: whats the value of a M5 Diesel??? in reply to melvin, 03-01-2008 07:40:06
In my opinion if you want one , it is close to you and as stated YES, if none of the above are true then NO....my 2 pennies
Alan K
03-01-2008 08:00:04
If it has had a complete engine overhaul,and is in decent shape it might be worth that. Diesels arent cheap to overhaul anymore. A person has to be careful, as years ago sometimes an over haul meant grind the valves and put in some new gaskets.
