Minneapolis Moline Tractors Discussion Forum
Valve cover gaskets
playin possum
02-28-2008 16:15:50
I just got my MM G restored and running, and the rubber gaskets for the valve covers leak oil (yes the nuts are tight). Is there anyone making cork or some other material gaskets that don't leak? Thanks
Alan K
03-03-2008 08:06:27
 Re: Valve cover gaskets in reply to playin possum, 02-28-2008 16:15:50
You might have to try a sealer also. I had the same problem on my ZA valve cover gaskets.
k schwartz
02-29-2008 21:16:52
i myself prefer the rubber kind. i have not had them leak. Cork ages as it rots away and becomes brittle. did you permatex one side to the valve cover?
LW
02-29-2008 07:04:32
There are heavy duty ones from Lubbock (thicker)
T.R.K.
02-29-2008 06:13:59
I always made mine out of 1/8" cork. The kind with rubber binder in it. I wasn't even aware they were still available.
